T
theUltamateTBM
06 m7 ovs with aero 53 looking for fuel psi box numbers and clutching for 6 to 10 thanks
sorry 6-10 was my elevation I am currently set at 6 psi boost running a pure logic box and my fuel pressure is at 40 my clutching I am unsure about as I bought the kit used but currently is a black primary with 689/69 weights and the secondary is a grey spring torsional set in the middle hole with what I think is a straight 36 helix the sled is a 153 with 07 cat rails and a power claw thanks
8400 maybe a bit more my afr is lean in the low and mid my mid is around 12.4 but right off throttle is in the 13's my wot is 10.8 in short bursts and it pulls very hard my engagement is at about 3600 and is very smooth and comes in really nice
it has a bog in the mid sometimes but it runs good at wot and pulls like a turbo should as far as leaning out my wot am I going to want to adjust my boost fuel on my pl box?
