I
izzni
Attached is a picture that I've overlaid some red text on. Can anyone confirm that I've identified the outputs and inputs correctly? In addition, can anyone tell me if input A or input B is the thermostatically controlled one, assuming they are indeed the inputs. I'm guessing that A is thermostatically controlled. By the way where is the thermostatic? Thanks!
For those who have no idea what this is, it's the water pump.
While trying to figure out what was a cooland line versus a crank vent line I discovered that the throttle body has a coolant line that runs to it, and then goes to the cylinder, and that I believe that it will only have coolant moving through it when the thermostat is open (since the line comes from the coolant tank). It also has an oil cooler built into the oil filter holder.
