Western Power Sports sells some which we installed on a 09 which are Blue Anodized and you use stock bolts, They are junk and only get two threads onto the bolt.,The ones I purchased from starting line came with longer bolt and works wellPlease tell my what your opinions are, on brands of quick clickers.
I'm clueless, I started shopping but just don't know the differences.
Searching here did me no good.
I'm riding a '04 Summit w/ 144 track
I was bogging down in the deep pow this weekend.
Thanks in advance
-Marty
Cudney Racing - search the internet and then call Bill. He makes them with the longer bolt so that you can thread it all the way on..... Best ones I have used. Lots of guys on here sell them as well, but get the longer bolt ones, accept none other.
NSC
Uh, changing your clickers in a couple of minutes versus a max of 10 minutes.
Click, Click, Click is all it takes.
Some people just dont read directions!
The Quick Clickers are not junk, you just didnt follow directions included in the package to install them.
Somehow we have sold over 16,000 "junk" products to satisfied customers. Go figure.
Thanks alot for the great recommendation, "buddy"!
Now thats the correct answer!You win a truckload of snow...i checked and it took me three screws to get my nut off! a blonde (1) a brunette (2) and a red head (3) that did the trick! Wait!! are you callin my sled junk??? I'll get you for that bob!!!
No! Be carefull pulling out the bolt ther is a washer inside that can fall in. make sure your bolt is vertical when pulling it out in a way in that you are looking down at the numbers on the bolt head. after you pull the first one look inside the hole and you'll see what i meen. Good luck too ya
Yes we read your instructions. Quick Clickers kit does not provide longer bolts to allow the nut to thread on,{Much cheaper to produce} We measured several times and 2 to 3 threads were all that held these on. Other kits provide the longer bolt for a reason!I will not run these and anyone who takes note when they install will get worried as well.This kit is a joke[A cheap attempt to copy the others which work.}Anyone reading this post with these, Mark with felt pen and unscrew the nut, Then tell us how many turns before the nut fell off?
