help mcx 180 won t start!
it just got it and it ran yesturday. the turbo and everthing were profesionally. it has 360 miles on it . i moved the boos guage on it and went to drive it on to my trailer and it will not start like i said it will fire once then quite.
Check the battery. If its low or not holding a charge the sled cant fire or run. I've seen this before.
you mentioned you ran it yesterday! Did you run it on snow? Check wiring for moisture. corrosion. A little moisture where is shouldnt be can cause alot of issues. Just went through the same thing. corrosion in the wire harness. Nightmare.
Is it outside, if so check to see if you can hear the fuel pump cycling when you turn the key on. If not take a hair dryer to the relays in the nose of the sled and it will start. You can replace the fuel pump relay with a better one from your dealer if thats the problem. Good luck. Shad
