MPS:
Does the sleeve come up vertically through the floor?
It could be hydrostatic water pressure from ground water under the house.
Do you have a sump pump in your basement? If so does it run alot?
How could you test this.............. Hmmm
Could you introduce a dye to the water line down near the well somehow?
Leave the faucets off and then if there is a leak in your line water coming through the sleeve will become colored with dye....
Or can you monitor the well pump for cycling when all water is turned off in the house?
As an extension to this, you could try and plumb a bypass to your expansion tank, so any demand from the house, or a leak in the line will trigger the pump to turn on. If you bypass the tank and it cycles, then you know there is a leak in the line somewhere.
Disclaimer:
I have no knowledge of well systems. Any advice given here is by a complete idiot, so take my advice for what it is......
Have you tried to pressure test the inner pipe? Check that out to make sure you do not just have groundwater coming in from a leaky outer pipe. There must be a reason they have already put a second pipe inside.
more then likely it's leaking outside where it enters this lead pipe. thats why most of the time you go under the footing vs through the wall where the dirt can settle and start to shear the pipe where it enters the wall
Slut....a leaky pipe? You should get that checked out!!!![]()
go take a shower, your stinking up this thread already!!!!!haha
