it starts and idles normal. but throttle response is VERY sluggish and only the Mag side part of the Y pipe gets hot.
when riding it revs to 5800-6000rpm then no further like it is being limited or governed.
the injectors are both squirting the plugs have good spark there is air available. so the only things left are timing and compression
I dont know how to check timing but the compression seems WAY down
93/103 if I add a Light oil it rises to 115/115. Dealer says this is not necessarily bad a "tad low but not bad" were his words.
that seems really low to me...
can reeds lower compression 10 psi? I have the carbs off and as soon as I can get back to it I will check the reeds.
any help please let me know I want to go again thursday and friday.
spomey
spomey
