A
abd
New member
Help, found loose ½" locking nut in belly pan, M8 2010
Found a loose ½" locking nut in right side of belly pan of my 2010 M8 LE, it was lying in the "pit" below the brake disc.
The nut has a purple plastic "locking insert", it seems to be the same dimension as the engine mount nuts.
Are there 4 engine mounts? I saw 3 engine mounts on left side and 1 on right side, none of them were missing a nut.
Also the 2 nuts holding the steel plate in front of the steering post seemed to be the same dimension but they were also in place...
Would appreciate any help to find where it has come loose, doesn't feel good driving it now with that kind of heavy/important bolt loose..
Thanks
Thanks
