help 2008 m8pg
B
burried
New member
i went from 80 gram weights to 77 rpm gont go higher than 7900?
i have adjustable helix tightened loosen>??? what happens if i tighten the helix?
i want more rpm
thanks
I wouldnt tighten the helix you will let off the flipper and go over the bars id just drop 2grams off the weights what sled,turbo,boost?
What primary spring are you running? The higher the finish rate the higher your rpm will be. Did you have the correct rpm before with the 80 gram weights?
didnt change i had 80 first
im using the titanium oem snow pro spring that came with the sled
I'm running boonie's clutching w/ 77 gram big dog's at 8100
with my 46/36 helix
I would check that your primary spring isnt broken. If it looses tension the weights will over clamp on the belt and thus a drop in RPM. Also how old is your belt? A worn belt can grip tighter and also loose rpm.
