Ran this in the yamaha section but I am desperate...
New crank and pistons. Engine runs fine. Lined everything up...so I thought. Clutches were fine when I pulled it apart. Now on the track stand it will only pull 6000rpm...same on the ground.
Wanted to ride in the morning...any ideas where to begin.
Belt seems to be a bit tight so I am going to try to move the engine closer to secondary and see if that helps.
