K
From what I've read the timing sensor won't create a "no start" situation. Pretty sure that is correct.... but maybe not. I'm leaning towards the stator being on it's last legs, or the wiring creating the spark problems.
For now I know for a fact that I'm getting way to much fuel. I'm thinking either the injectors are toast (would be very odd to have both injectors stick at basically the same time) or the regulator is toast and the fuel pressure is through the roof. I'll solve this problem then move on to the spark being weak/intermittent. With this much fuel dumping into the cylinder the plugs will get fouled immediately almost regardless of how much spark is there. I have a spare M7 with mine that I'll be swapping parts to and from. Eventually I'll try the harness.
