If someone was going to sleep in a trailer would one of the MR Heaters be ok? Its in an insulated trailer and just the front 10 foot LQ's section. I'm also putting a carbon monoxide sensor in there to. Any thoughts?
I have also been looking at the ProCom & Mr. Heater wall mount vent free heaters. Here are my questions for you guys who already purchased the ProCom: which model did you purchase? I was looking at: http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200332747_200332747 but noticed that is says will not work above 5,000' elev?? So then i looked at this one: http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200362127_200362127 but it says it must be operated w/a 100 lbs propane tank. I want to mount an rv tank under the trailer and so far the largest one i can find is 30 some gallons.
What's your experience w/these. The elevation that the heater will be used it is typically higher than 5,000'. What kind of propane tank setups are you guys operating these on and how long are they lasting? Thought about puttign one on the tongue of the trailer, but i don't think their is room on the tongue of my trailer. Thanks for your help!
am thinkin of installing a blue flame ventless propane heater in my enclosed trailer, after following this thread for a while i am wondering ,even though my trailer has 2 fresh air vents in it, will it work safely while parked,to run this heater to heat the trailer with my sled inside the trailer...2nd ?, why is a forced air furnace(propane ) not suceptable to iginiting gas fumes(precious sled) in the trailer,even though there is a flame present in the burner...is it is because the furnace is vented???
I can't speak for everyone but the procom blue with the 5000ft limit seems to work just fine at any parking lot I've been to in Wyoming 7500ft +.
Mine here @7,500' in Wyomings Parking lot's doesn't work and Pro com advised me about it shutting down @ over 5,000'...
It operates but not for a extended period... the ODS shut;s it down ....So I put it in my Garage @ 6,700' and she warms up a 3 stall garage tosty!!!!
Like I said before I run the Ranni-- Way better and HOTTER than the blue flame style......just likn the forced better to dry my things and not have a saunna like the vent free direct heat styles do ( Ranni and the Pro crom) The direct heat is faster to get dressed by.
MD
GPR /
My Rinnai heater is the Tropic line- and is the 30,000 BTU .,,,
You cannot go wrong with that type.. it has been up to 9,500' and runs strong
There are some on ebay but this one has the ODS / miine does not!! http://cgi.ebay.com/RINNAI-TROPIC-2...5|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
MD
I have a tank inside the trailer on a long rubber hose so you can keep the propane inside while travelling and it (the tank) stays much warmer than outside. I had problems with the tank valve freezing up when it was outside and it took forever to get the propoane flowing. Now that it's inside, 1 click and it fires right up. With the extra long rubber hose, you can open the V and set it out on the nose for safety reasons, but its been just fine inside and this is the 3rd trailer I've owned. The heater is a SunStar 2700btu and that trailer gets toasty QUICK! Put a piece of diamond plate behind the heater for a nice looking mount as well. This will allow you to center the heater or get a secure mount if you're beams aren't the exact width of your heater.
