It says Terra Alps so obviously it's Terra Alps.Is this bone stock stuff ?
Because of dome cracking and combustion entering coolant it did get hot because of this . Crack in dome is is suspicious of 90 degree angle machining steps weakening domes on coolant passage side . Cut the dome in half to show this .
Start enjoying life. A snowmobile motor isn't worth being that upset about. Have a good day.
After 40+ years in engineering (Mechanical) I can still remember one thing I learned by my 2nd year in college or maybe before I got out of highschool shop class and that was square lathe cuts cause stress concentrations leading to stress failures!! If those step cuts would have been done with a larger radius cutter, I would bet there would been less stress concentration and probably not caused a crack. IMO only and worth just what you pay for it!!! NOTHING!
gtwitch in wyoming
