Headlights don't work
I just purchased a '05 RMK, Vertical Edge 800, w/ 1800 miles, but very clean in appearance. Apparently the headlights were working when I looked at it prior to purchasing it but on delivery (few days later) the headlights do not work. I have changed the bulbs but that did nothing. I am new to owning sleds and do not have any manuals.
Are there fuses? Any help would be appreciated.
Thanks,
Hey, welcome to snowest, first thing I would look at is the switch that changes lights from hi to low. The next one is the regulator, or rectifier on that yr (not sure) they fail at an alarming rate. If you can't find the reg, go to ronnies mail order lookup yr of sled & electrical cat. & it should take you right to the reg. Good luck. You never stated if all other lights are off also? I.E. tail lghts, dash lghts.
I had this issue with mine. It was intermittent at first (would only fail in the middle of nowhere in the dark!!) it ended up being a loose connection at the stator (big white square plug). I disconnected it cleaned and put it back together with dielectric compound. Used a zip tie and no problem since. Two seasons ago. Hope that helps...less $ than a stator
