Yellow/violet is power supply wire, Blue is for high beams, white is for low, the black is ground.
You will no longer need the black wire. the black wire is to supply ground for the little illumination lights on the factory switches so you can see then at 2am when your hammered drunk coming home from the bar.
On your 3 way switch, the middle prong will be power in(yellow/violet) the two outside prongs will be the distribution ones. Now on most switches the prongs are reverse of what you think they are. So if you want (II) to high beams, your going to attached the blue wire on the (I) prong side. white will be on the opposite. Make sense? If you have any other questions let me know I've wired up several sleds.
Exactly what I wanted to know, thank you. I got ahead of myself and taped up my handlebar wiring harness up to the switch wiring, do you recall what the smaller thin black wire that has texture to the wire is? I’ll probably just put it together with the ground for the illumination wire. Put them together with a butt connector and heat shrink over top.
I show the black wire from the high beam switch that has the terminal on it. And then the thin black wire that has the texture to the wire.
