Has anyone used Mothers Powerball?
I was wondering if anybody has had any luck polishing their tunnel with a mothers powerball. And if the big one or the little one works better. (They have one that is about 6 inches diameter and one that is about 3 inches diameter) Thanks alot.
It works good, I used it with their Powermetal polish and it was awesome. You can polish it to a mirror if you put in a bit of time on it or you can just get it a bit shiny which is what I wanted. I used the larger one, but the smaller one might be easier to do the sides of the tunnel with around the boards.
awesome product!use a polish compound with grit and go down to get the shine!
Used the larger one on my dragon last year, you still need to put some elbow grease into it! Works good though;)
I used the big one, but I think I am going to get the little one. The big one is too big for everything except big flat areas. I can't use it on my truck rims.
I used the small one with mothers polish then followed with Bluemajic and wipe off with a real soft buffing cloth.
have them both and they both work good . the large one works good on larger places.
and smaller in the tighter areas and better finish.
Just used the big one on the weekend. Work great! I did do some wet sanding before hand to help out.
i've used the small mothers ball the last two seasons and wouldn't go away with it. The smaller one is perfect if your just doing your tunnel.
I got the smaller one, worked great have to be a bit careful on the tunnel stirups have to slow down the drill, or it shreads the ball. It only took me a couple of hours and a case of beer.
I use it. Get the bigger one and use the mothers polish in the squeeze bottle not the can. The stuff in the can works good too but is harder to apply to the ball.
It will take a few steps to make it shine good but after that the up keep is pretty easy
Here's my old Dragon
And my new nytro
