Has anybody managed to sort out the jitters (blowing belts, over-revving, etc) on the 2007 Revs?
Just curious, is Doo replacing the rollers and bushings under warranty?The ONLY issues I have had are with the primary rollers and the main bushings. Alot of people blame the TRA7, but the design is identical to the III, just eliminated the splines with a taper-fit (stronger and more precise). As for the rollers and bushings, hopefully Doo will have yet ANOTHER fix. The latest update is good for 4-500 miles before they show excessive/premature wear.
BTW, I swapped out the primary to that stiffer spring you recommended and it's working great....got the RPM I was looking for. Didn't bother doing the helix yet. Thanks again!
These things really do run hard when you get them setup. There were some hill drags here last weekend and I couldn't find a stock M1000 I couldn't edge out....the hard camo on packed snow didn't hurt either, but the rev would keep creeping ahead all the way up...say what you will, but that was the outcome.
QUOTE]
Yes, Had mine done less than a month ago. Now the sled just rips. The only thing in our group i couldnt out climb was a supercharged vector.
