Yes I listened to a podcast where they mention a kit to raise it to normal Indy 550 height. But is this new shocks or simply a cheap atv style lift using steel brackets?
This is the upgrade kit:
https://snowmobiles.polaris.com/en-us/shop/accessories/shocks-suspension/2883939/
This is the list of everything it includes:
1542993 1.000 EA ASM-SHOCK FRONT TRACK
1823875 1.000 EA ASM-SPINDLE F/C,LH
1823876 1.000 EA ASM-SPINDLE,F/C,RH
1823883-309 2.000 EA ASM-TIE ROD,WIDE,NAT
1823916-070 2.000 EA ASM-SKI SVC BLK
1824010-067 2.000 EA ASM-SHOCK IFS,WIDE,BLK
1824624-067 1.000 EA ASM-ARM LOWER CONTROL LH BLK
1824625-067 1.000 EA ASM-ARM LOWER CONTROL RH BLK
1824626-067 1.000 EA ASM-ARM UPPER CONTROL LH BLK
1824627-067 1.000 EA ASM-ARM UPPER CONTROL RH BLK
2010431 1.000 EA ASM-LEVER,HTR,HI/LO 35.5MM
2205307 3.000 EA SLUG-43 GR,CVT,135-1083
3090428 1.000 EA EC55 CDI INDY
3221094 1.000 EA SPROCKET-18T,3/4W,15 SPL,HV,PM
3222192 1.000 EA SPRKT-42T,3/4W,LWT,HYVO,PM
5010422 1.000 EA BUSHING-.385X.618X.95
5136910 2.000 EA BUSHING-15.88X10.13X76.20
5137360 4.000 EA BUSHING-M10X17.5X30
5220646 4.000 EA WASHER-DOMED
5333905 2.000 EA SLEEVE-.385X.560X1.24
5333906 1.000 EA SLEEVE-.385X.560X1.72
5414450 1.000 EA STRAP-LIMITER
7043281 1.000 EA SHOCK-R/T,ARVIN MPV
7043859-329 1.000 EA SPRING-TOR,.347S,80,10#,LH BLK
7043860-329 1.000 EA SPRING-TOR,.347S,80,10#,RH BLK
7044154 1.000 EA SPRING-DRV,202#,CVT 1151-1135
7044155 1.000 EA SPRING-DRVN,90#,CVT 5951-1006
7515391 1.000 EA SCR-5/16-18X1-1/2 TX/TAP,Y
7518070 1.000 EA SCR-5/16-18X1,TRX,GR5,Y
7518917 1.000 EA SCR-M10X1.5X95 HX FLG 10.9 ZOD
7519004 2.000 EA SCR-M10X1.25X20 8.8 HH ZOD P30
7519015 2.000 EA SCR-M10X1.5X75 10.9 HCS ZOD
7519145 2.000 EA SCR-HXFL-M6X1.0X12 8.8 ZOD P30
7542344 2.000 EA NUT-5/16-18,NYLOC,THIN-Y
7547263 4.000 EA NUT-3/8-24 FLG LOC
7547332 14.000 EA NUT-M8X1.25,FLG,NYLOC-OLIVE D
7547423 13.000 EA NUT-M10X1.5 HFN NYLOC ZOD
7547464 2.000 EA NUT-HEX-M12X1.5 8 ZOD NYL
7555730 5.000 EA WASHER-.189X.314X.015 - AL
7555806 6.000 EA WSHR-FL .406X.812X.065-Y
7556212 4.000 EA WASHER-7/16 SAE,STF,THRU-HRD-Y
9929062 1.000 EA INSTR-EVO UPGRADE
