Has anyone put big boost to Alpine's rearmount?
K
kraut
What would a guy have ta do ta get 20-30 more hps out of the Alpine rearmount 200horse Nytro kit? I see a few of these forsale and was wondering if it could be done afordably.
fueling ie bigger injectors + a fuel box to run them.if that kit runs on the stock fuel pump you would need a regulator & fuel pump too.
Was in the same boat. I did a fuel pickup/pump/rising rate regulator. Turned it up a bit, worked great other then blowing the throttle body's and inter cooler off due to lack of hold down. I cooked my dobeck box, so got in touch with Neil at Boost-it. I still need to build a hold down for the inter cooler, but the ratchet strap has worked so far and the sled works great. The main parts of the kit are up to the task, just needs fuel/tuning to make it work.
I'm running the low boost rear mount Alpine kit. Would like to know what you find out on upping the boost.
If a head shim & boost it kit with new fuel reg would work that is great.
