Handlebar Riser
W
Weatherbyman
I have installed a 2" riser block on my handlebars, way better. I got it from cutting 1" from a 3". Anyway, I would like to add the other 1" section but have no free play left in all the wiring from the handlebars through the console.
Recommendations?
I have thought about just adding about 4" of wire to all the connections, but that is a lot of wires to splice.......any other ideas?
I re-routed my wiring and was able to install 6" of riser with no problems, still on stock length throttle cable as well. I did however change to a longer Fly brake hose
I went 4 with a little rerouting wish i could go 5 but maybe later when I can afford FBF cables
I got the other 1" by re-routing my throttle cable and removing some of the zip-ties on the wiring harness.
Thanks for the suggestions, I appreciate it.
