I your not running lights you have enough power on the FI yammies to power a set of handle bar grip heaters..
To that note have you guys seen the water taps some Ice racers use to flow H2o from the motor threw the bars?
Looks to work well, not so sure about hose routing.
Good to Know! I plan on using the cyclops light with the 4 hr batery pack in my back pack!!Thanks!!
I was planning on getting your Penetrator 310 Light Kit for my 11' KX450F this winter. I imagine that I can have grip warmers and the light installed as long as only one product is running at a time, right? I know having multiple things hooked up can sometimes create additional electrical issues so I wanted to be sure.
The yamaha web site says the YZ has a 100 watt stator, so wondering hoow much it takes to actually run the bike?
Fuel pump ,,injectors,, ecu,,etc etc wish I knew the real wattage draw???Hate to smoke an ECU ala polaris dragon,way in the back country!I have been forced to spend the night out 3 times now I heard that the 4 th time you DIE!!
Strange but each time it out it got worse!LOL Yes I have my spot programed to call the corona distributor!
Any way took the air box out of by backaswards yamaha and figured out how to fix the air box problems, goint to be supper easy!may be lean running when I done but thats why I got the GYT programmer!
