Hand Warmers
Having problems with hand warmers on 06 900 not getting as hot as they used too.Is there a way to check the volts to see if there getting the right volts at the grip
hand warmers
I am guessing 1 set of "windings" isn't working. They have 2 printed circuits on the warmer. On low 1 heats up, on high both get power and heat up so you get twice the heat. It is not a matter of how much power per say that goes to them but if both circuits are getting juice. Probably a broken wire at the grip or one of the leads may be loose at the switch. Switch will have power in on 1 lead and out on 1 when switched to low and out on both when on high.
^^correct
i would bet your warmers are just worn out/broken wire. time to replace. get RSI and youll be happy.
