MOTOR BLOWN - update -Had to take the 09 rmk 700 in - motor knock!
Had a mechanic checking my belt deflection as this is new to me....started engine and he said what is with that!!!! Told him I just noticed a noise last couple days, but thought it might be ice...or loose belt (thus belt deflec check). he wiggled primary clutch and you can hear a noise...start it up with hood up..whoa...really loud...did not notice if it increased with revs as it is such a fast knock.....guy said to me wonder if it is the wrist pin..yikes...
Took it to dealer as I have one year warranty....worried they say can't find it, or normal and then my darn warranty runs out at end of season......ahhhhhh
only have 400 miles!!!!!!
Called dealer today...they are rebuilding the engine...were still tearing it down...needed new pistons and cylinders for sure....felt the cause was overheating as the antifreeze jug was slightly enlarged....told dealer I have never seen it go over 126 and usually sits at 122-120.....unless digital part is off....said I thought they can be run to 160...dealer saw his go to 195 once pulling a guy out then light came on and shut it off....so felt it would have to be in the 200's...told him no way as drive exact same place as son as we go together, I have 400 miles, he has 550 as he has gone with some friends..his 600 is fine, mine is toast so if we drive in same conditions next to each other both should have heated.....dealer just trying to find cause so they do not rebuild and have same problem again...just hope I have enough snow and time when it is done to make sure it does not happen again as I only have the one year warranty and purchased it in Nov...
so just got snow and now motor is toast on new sled...thought the 700's were bullet proof!!!!ahhh.....
Dealer is being very good though as I have a ride lined up and cabin next week and he is going to let me use his sled....now that is a top notch dealer!
