u have to go old school on the turbos to check for lean
pull power valves and check piston wash, I have a 09 TM901 boonie Rg/PG turbo with a D&D 901 big bore kit, my egt's are high 1360-1380 have seen 1396 flash once, if I enrichen the box to where my egt's are around 1290 WOT it is boggy and runs like crap,, running 50/50 112 and super under 8lbs of boost u must of been really lean, call Junior at boonie's and he should be able to give u some starting numbers, but u definitely need egt's on any turbo sled. good luck, if u Go 900 big bore , I have posted my boost numbers and boonie box numbers in turbo section. I'm running it as a PG with 93 non ethanol, 7-7.5 lbs at 4500-8500
