Hi everyone so decided i am gonna turbo my sled and i have a few questions hope someone can help. I have a 05 M7 with a speedwerx 800 BB kit in it. I have decided to run a garrett 2871 turbo with a .64 A/R with an attitude box. I am gonna ditch the speedwerx pipe, v-force reeds, and boondocker box and go with a stock pipe and reeds and go with an attitude box. I am only gonna run about 4-5 lbs of boost and run a 50/50 mix of premium and av gas. The oil pump I am gonna get from silber turbos and plan on running a 50 mm blow off valve. I have koso egts already installed and will be running an AEM air fuel guage. The oil tank, charge tube, exhaust, and intake i will fabricate myself. Some of the questions i have are:
- the 2871 is water cooled do i just tap into the cooling system for it
- what spring should i have in my blowoff valve fairly light i presume ( i have no idea)
- any special things i need to know about fabricating an oil tank and intake box?? I can TIG weld very well so everything will be aluminum
- the wiring can be questionable on these old M's so any help to keep it alive would help
- with this low of boost is the stock injector setup sufficient enough and what do i need for a fuel regulator etc.
I am sure i will have more questions as this progresses and i apologize for the long post but had to start somewhere. Any help will be greatly appreciated. Thanx in advance
