Goggle bag
the weird triangle one above the muffler? yes. you ditch the rod tho cause theres no hole in the CF. if you have an aluminum frame it will have the hole.
The goggle bag on my '14 came with a rod, it has a little rubber deal that the rod goes through and that sits on top of the CF and is zip tied in place. hasn't come loose or had a problem. 1700 miles on it so far...
hmmm. yah i ditched my rod and was fine all last year. i wonder if i still have the rod and that rubber thing.
Probably a long shot, but does the 2012 goggle bag fit the 2014 pro?
Yes. Put it on 2 RMKs since 12. As mentioned, just a slight difference in install between CF and aluminum spars. You may also make a few other changes to the rear console-hood attachment - I did. But bottom line, excellent for drying facemasks and goggles. Awkward if you run a muff on top of the pipe stinger. If you need to dry while you ride, haven't found anything that works better...
That's how I have mine set up, haven't really had a problem with the muff pot. Did notice that the foil is starting to come off the underside of the goggle bag, but it's not a big deal
