Ok, lots of good questions from everyone. I just got pics of the new trail can. I'm going to do my best to post enough info to hopefully answer everyones question. Remember, you can always call GGB direct. Ask for Graham and tell him you saw it on SnoWest and talked to Steelman. I'm working with Graham to promote his product here on SnoWest and by letting him know, it will let us know if it is working or not. Please below info.
Thanks,
Rob
Mountain Models
GGB Lightweight Mountain mufflers provide a huge weight savings with an aggressive exhaust note. Each system fits securely in the stock location and weigh in at a mere 3.5 - 6 pounds each. Muffler is finished in a high heat satin black and installs without any modifications. This Mountain muffler is designed specifically for use in areas where increased sound levels are not an issue.
Trail Models
GGB Trail mufflers offer a true, trail tuned sound that won't draw unwanted attention or leave you "sound fatigued" at the end of the day. Each system is designed to fit securely in the stock location, using stock mounts and weigh between 5 -7.5 pounds each. All GGB trail mufflers are built with sound control in mind and offer awesome performance without all the noise. Each muffler is finished in a high heat satin black and installs without any modifications.
Our tests were taken 3 feet from exhaust outlet at a 45° angle back, 1 foot off the ground. Unfortunately this is not how the SAE or enforcement perform the test but it gives a comparison. We will perform proper tests this winter.
Tested - 2012 RUSH 800
Idle 3500rpm (just before engagement)
Stock - 86 94
GGB Trail - 90 97
Mountain - 91 104
The Trail can will meet SAE J-2567. The Mountain can will not.
SAE standard test 88 decibels
*Jan. 2004 SAE J2567 stationary test overview: The sound meter microphone is placed 4 feet above the ground, inline with the exhaust outlet/center point of multiple exhaust outlets, on the side of the snowmobile toward which the exhaust is directed, 4 meters distance from the snowmobile longitudinal centerline. The operator holds the brake during the test, starts and runs the engine up to normal operating temperature, then slowly opens the throttle until a steady 3,750 to 4,000 rpm is achieved for not less than 4 seconds. The test is immediately repeated and the two readings averaged.
2 Stroke
In a two-stroke engine a certain amount of exhaust backpressure is needed to prevent unburned fuel/air mixture from passing right through the cylinders into the exhaust. This is acheived by the expansion chamber directly connected to the exhaust port of the engine. The expansion chamber connsists of 5 main sections: Header, Diffuser or Inverter cone, Mid section, Baffle cone and finally a Stinger. The stinger acts as a "pressure bleed valve" before exhaust gasses leave the pipe and must be sized properly to create a "plugging effect" necessary to reach maximum performance. If the stinger is oversized exhaust will escape to soon, if it is undersized to much heat will be created in the pipe and the engine. The stinger size can either make or break the pipes ability to perform as designed. As the exhaust wave has not yet reached the atmosphere, the same holds true for the muffler. The muffler acts as an extension of the stinger and must maintain the correct back pressure (plugging effect) or performance levels will suffer as a result.
General thinking for a performance muffler is that bigger (more flow) is better. While this is true to a point on a 4 stroke engine, this is not the case on a 2 stroke engine. A 2 stroke muffler must be tuned to the expansion chamber to provide proper back pressure levels.
After the back pressure values of the muffler are determined the sound attenuation of the muffler must be addressed. While there are numerous different muffler designs available on the market, most mufflers for internal combustion engines use passive silencing methods. These muffers fall into two general categories, reactive and dissipative mufflers. Reactive mufflers make use of seperate chambers and defelctors to direct sound back to the source and are generally better at reducing low frequency sound waves. Dissipative mufflers generally use a straight flow through design with perforated screen and filler materials scrubbing off sound waves and transforming them into heat. This type of muffler is usually best at reducing medium to high frequencies. With that in mind, a quieter high performance muffler would combine the two technologies and cancel a wider range of sound waves. And this is exactly the DNA of which the GGB trail muffler is created from.
4 Stroke
As we mentined, bigger is better when it comes to exhaust flow on a 4 stroke motor. While this is true to a point for peak power, bottom end and mid range power can suffer from to loose of an exhaust (to much flow). Exhaust temperatures inside a tube can very significantly, from as high as 500 to 1300° F with the average sonic wave traveling at approximately 1700 feet per second. If an exhaust systems tube diameter (flow) is to large for the engine's displacement, wave speeds will slow down, exhaust temps will drop, bottom and mid range power can suffer, as well as the fuel economy. For the best overall performance all GGB 4 stroke mufflers on this site are designed and built for for stock and improved stock engines. If you have a heavy mod engine contact us about a high flowing muffler.
Store Policies
We want your experience with us to be a positive one. It is our intention, as a business, to provide quality products that our customers can confidently use and recommend to others. We encourage you to contact us directly if you have any questions about our products, services, or business.
Reaching Us
Our office hours are Monday – Thursday 8:00am - 5:00pm, Friday 8:00 – 12:00pm EST. We can be contacted by Phone 705-382-5275, Fax 705-382-5276 or
email.
Privacy Policy
We value your business, and respect your right to privacy. Our web site is a safe environment for anyone who visits or purchases from us.
We use the information you provide about yourself when placing an order only to complete that order, to send you our newsletter and to use it internally for informational purposes. We do not share this information with outside parties except to the extent necessary to complete your order. In no other way do we share your information with anyone else, for any reason.
Warranty
Manufacturer warrants all products and parts of its own manufacture against defects in material or workmanship for a period of 2 (two) years when used under normal operating conditions as determined by manufacturer upon examination, and when owned by the original purchaser. Manufacturer will repair or replace (but not install) any part or parts it manufactured and deems in its judgement defective against material and or workmanship. If requested by the manufacturer, the part or parts for which a warranty claim is made are to be returned transportation prepaid along with copy of original receipt to our warehouse. This warranty becomes void if the part or parts claimed to be defective have been repaired, modified, or changed in any way or when the part or parts have been subject to neglect, misuse, accident or racing or when a failure to follow proper installation procedures occurs. We make no other warranty, express or implied, and make no warranty or merchantability or of fitness for any particular purpose, and there are no warranties which extend beyond the description on the face hereof. No employee or representative is authorized to change this warranty in any way or grant any other warranty. The remedies herein above afforded to the purchaser are exclusive of all other remedies provided by law. Manufacturer shall not be liable for indirect or consequential damages where the loss sustained is of a commercial nature.
Warranty Claim
Warranty on GGB products are applicable to the original purchaser only and are not transferable. If a warranty claim is to be made please contact GGB with the reason for the claim prior to returning any part(s). If a warranty claim is granted, a number will be assigned to that claim. This number must also be visible on all parcel(s) returning. Phone 705-382-5275 to obtain a return number. All returned parts require a Return Goods Authorization number obtained from GGB prior to any returned shipments.
Product Improvement
GGB reserves the right to make product improvements at any time without responsibility or obligation to make similar changes or add similar improvements on parts delivered prior to those changes.
Warranty Claim
Warranty on GGB products are applicable to the original purchaser only and are not transferable. If a warranty claim is to be made please contact GGB with the reason for the claim prior to returning any part(s). If a warranty claim is issued, a number will be assigned to that claim. All returned parts require a Return Goods Authorization number obtained from GGB prior to any returned shipments. This number must also be visible on all parcel(s) returning. Phone 705-382-5275 to obtain a return #.
Return Policy
GGB will gladly accept new, unused product returns within 30 days from date of invoice for exchange or refund, at your option (all custom orders excluded). Product must be returned in new, unused condition and in original packaging. All products returned are subject to a 15% charge for re-packaging. All returned parts require a Return Goods Authorization number obtained from GGB prior to any returned shipments. This number must also be clearly visible on all parcel(s) returning. Please phone 705-382-5275 to obtain this number.
PLEASE DO NOT RETURN ITEM(S) WITHOUT A RETURN GOODS AUTHORIZATION NUMBER AS ALL SUCH SHIPMENTS WILL BE REFUSED AND RETURNED TO SENDER
NOTE: GGB recommends that you use a carrier that offers shipment tracing for all returns and either insure your package for safe return to GGB or declare the full value of the shipment so that you are completely protected if the shipment is lost or damaged in transit.
Shipping and Handling
All shipping rates in-store apply to orders shipped within the Continental US and Canada. If you are outside of these areas you can
contact us for a shipping quote before you purchase or make your purchase in-store and we will charge you accordingly for any additional shipping fees. All orders are processed within 2-4 business days and ship via Expidited service. Normal delivery is between 3-7 days and a tracking number will be provided for each order. We reserve the right to choose the courier of choice based on price, quality and service.
