A anderson Member Premium Member Dec 31, 2009 #1 I bought a 06 polaris 900 RMK 151 track. I pulled the cover to change the gears. I wanted to put in 19-43 gears.. It has 18-43 in it. how do these compare.
guidoxpress Well-known member Lifetime Membership Dec 31, 2009 #2 19/42 is the BEST setup you can run on an 06...but the ones you have now will work fine..
G ghostwhite Well-known member Jan 1, 2010 #4 Give some addition info such as Primary spring spec and power mods such as pipe for a better answer.
A anderson Member Premium Member Jan 1, 2010 #5 i have a 64-38-25 helix black and green spring not sure what spring in helix is
T Treeslut Free Member Jan 1, 2010 #6 11-72 would be the same as 10-74 witch is for flat land for 6000ft you want 11-68 or 10-70
