I ride an 06 X-fire 700. For upgrades this year I would like to bump from my current 136" X 2" to a 144" X 2" track. Additionally, a re-gear is in order. Any suggestions on a ratio??
If your reason for gearing is the track change.
I would not change any thing you are only adding 8in of track 4 of it on the ground not enough to worry about. That machine will handle the change no problem. For your piece of mind AC does not change weights or gear ratio from a 153 to 162.
They are stock M7 gears..63/57. My stock X-fire gears are 65/55.
I was thinking of doing the same thing with my 06 crossfire 700 when I put the 144 X 1.75 backcountry track on it, but I thought the stock gearing was 60/60. Never heard of the 65/55 gearing in a crossfire, but that doesn't mean anything. Do you know how to tell what gears you have with out taking apart the case for the gears?
