Gearing on 2004 rmk 700?
not sure what is stock but I would go with a 19/42 or a 19/43 makes a big difference
Factory Gearing or Dealer ??
Remove the can and Pipe Open the Chaincase up.
Check your gears they are plainly marked, Clean things up, then put either 20/42 or 19/42 in, depends on if you want to buy a new chain.
Hold the hand Break to losen the nuts, don't use air.
Most polaris sleds are geared way to high, then you never know what the last owner or the dealer did to it.
