If the 8's are a 2.86 pitch and the 7's a 3" pitch, then its about 8%.
3" pitch drivers/tracks have 3" between teeth/window centers.... 2.86" pitch drivers/tracks have 2.86" between teeth/window centers.
A 3" driver will be larger in diameter than the same tooth count driver in a 2.86" pitch.
7 tooth 3" pitch driver = 6.68" dia
7 tooth 2.86" pitch driver = 6.37" dia
8 tooth 2.86" pitch driver = 7.28" dia
8 tooth 3" pitch driver = 7.64" dia
You will be under-driving your track by a factor of .92 when you run 7 tooth 3" compared to 8 tooth 2.86" pitch.
You will be over-driving your track by a factor of 1.05 when you run 8 tooth 3" compared to 8 tooth 2.86" pitch.
FYI I really like 2.25:1 gearing that my TKI belt drive kit gave me. Also tried 2.42:1 but it felt slow. May of needed more clutch weight? I would think this is a better way to go than changing the drivers as changing drivers changes attack angle and for all the work, you gain no improved reliability with a driver change.
OK taking these no's, if ya go from 8 Tooth 2.86" P to 7 Tooth 3" P starting with 2.10 gearing ya end up with 2.273 gearing correct??
***Note forgive my ramblings, I set out to prove who was right and who was wrong, and the truth is neither one of you is wrong, just one of you mis applied which way the conversion was going. Read on***Wondering where is my math wrong??
I come up with a correction factor of .92 (1/x = 1.08695 ≈ 1.087 {8.7%} )
Where 6.68"/7.28≈.92
I've been wrong many times... so this is a sincere inquiry.
So I've been bouncing this around in my head for a bit and got to thinking...
Given the same final drive ratio, would larger drivers be more efficient? What I mean is if you were to put 7 tooth 2.86 drivers on your sled to gear it down versus keeping your 8 tooth 2.86 drivers and changing your gears to achieve the exact same final drive ratio. (Don't know if that's actually possible to get it exactly the same, but for the sake of this discussion, let's say it is) In the case of the larger drivers, you aren't having to bend the track in as tight of an arc going around the driveshaft, which would reduce resistance, right? Or am I mistaken?
