Lets say I bought a axys 2.6 qd model and have a stock set of 13-15 qd gears laying around and wanted a little lower gearing. Would they work with the axys drive belt seeing how they're 1 tooth smaller on top and 1 tooth bigger on bottom?
Maybe,,, '13 top pulley, '16 bottom pulley, '16 belt and Fire and Ice tensioner??
First AXYS mod???
Short answer.... No.
Actually i think it is going to work. I put 13-15 sprockets on my axys with the axys belt and the tension seems to be same as stock. I think its going to work but only time will tellWhat's the long answer?
Long answer... well... it seemed to work for Rich... but the math doesn't exactly...
Increasing one on top and decreasing one on the bottom is not the same increase in circumference.... I believe.
Best to field this one to rich racer... he's done it and has had luck... I believe.
MH, will you break down the math for us? I'm likely going to do this to my sled so I would like to see how "close" the numbers really are.
I could do it myself, but then my head would start to hurt and it sounds like youve already done it anyway Thanks, Eric
Mountainhorse, I do believe you are wrong here. The spacing from one tooth to the next tooth on the top gear has to be exactly the spacing from one tooth to the next on the bottom gear or the belt would not mesh. If you take one tooth off one gear and add it to the other, and use the same belt, you will have the exact same tension.
It will be close, and you will have nearly the same number of total teeth engaged, BUT the difference comes from the angle change between the top and bottom sprockets! Trust me I crunched all the numbers when the QD was announced to be released in 2012 for the '13 MY. While close and possibly close enough. It is not the SAME tension, if it were we could run any ratio we wanted as long as the total number of teeth remained the same. It does NOT work out, unfortunately. It may or may not be close enough to tolerate the difference. The choice is yours.
