Hello,
09 XP 800 154" Powertek
Pulled motor to do E Mod an S mod, rode first 27 miles life was good.
Went out again loaded sled on trailer gauges went blank with speedo an tach stuck at some random number. Grip heaters worked, sled ran good for another 30 miles. Gauges did random sweeps an beeps like normal startup while riding.
2 Days later sled did same thing again sweeping gauges, high beam light glowing, then temp, finally voltage light glowing dim. Never had a problem with sled running or power.
Checked engine grounds, cluster plug, take it to dealer check for a code?
Also fuel gauge does not work full tank = 1 to 4 bars on display, very random!
Side note: Sled had none of these problems before frame repair . I mean the gas gauge never worked or read correctly but I always had working tach an speedo.
Thinking ground?
All lights work, grips work sled runs like new, checked forum never seen a problem like mine.
Thinking ground?
