gas liine for garage furnace?
Dunatic
MODERATOR: Paid Premium Member
Does anyone here know how and have the tools to run a gas line into a garage?
No offense to anyone here who might be, but hvac isn't rocket science.
The tools needed consist of a pipe wrench and pipe dope.
Buy a fitting or two, some pipe and DIY. Make sure the pipe is secured, away from other conduits and electrical lines. If your still unsure of your work just have a qualified tech inspect it after.
Little more info would help. You (atleast many places) can not have a threaded buried connection.
How do you plan to run the gas line? On the outside of a wall? Inside? Underground?
What is the length of the run?
What size of heater?
Not sure but I believe if it is not done by a licenced contractor and it causes a fire it may void your homeowners insurance.
Seriously.
Your dealing with a potentially explosive product here.
BE CAREFUL.
There is a lot we can do on our own, once in a while its smart to hire a professional that will do all the proper pressure/leak tests.
When your dealing with gas, DON'T CUT CORNERS or you might end up homeless (or worse).
I ran the gas line for both of my fireplaces in my remodel. Just depends on where and how you have to run it?
Is the garage connected to the house or detach?
Where is the closest point of connection? My water heater was close so I split off of that line.
If you pay attention and take your time it is pretty straight forward. Add a t connection into the existing line. Make sure everything is sealed up.
Flex hose although a bit more costly can be your friend in many places.
