sloan188
Anyone have any thoughts about a fuel leak under the engine on a 900 fusion?
Think I got lucky today that the sled didn't catch fire!
Went for a 350 km flatlander ride in lanaudiere Quebec. Should have known something was up from the beginning. The sled usually starts 3rd pull when cold and 1st pull when warm...it took about 6 pulls to start when loading/unloading (suspect the fuel pressure was too low). Then we went for a short trip to montagne noire and couldn't get down the back side so we returned to the car parked at st donat and filled up. I used about twice as much fuel as I normally use for the mileage...rationalized this by the thought that tank wasn't full to start (but I knew it was because I checked it). Next couple of fill ups were exactly the same, I used almost double the fuel I normally do. Checked plugs and looked in the engine compartment (engine off) for signs of a leak but nothing. 350km later when we returned to the car, I got the flashlight out and checked the engine compartment again (this time engine running). Looking in from the PTO side in the hole between the clutches I could see fuel p$&%&%^ing out. I also found a bolt and a washer...they might have something to do with it....maybe vibrated loose and fell out?
Anyway, I'm going to check the manual and see if I can find anything???? Hope I can identify the problem and fix it without having to take the engine out or to the stealer....
