Fusion 900 Clutch weights rub picture.
I inspected wireing for rear brake light,, Rear running light is on, but brake light will not brighten when lever pull.
I ruled out the switch at bar,, ohm meter shows action.
So from bar going down into harness is Brown and orange wire.. it seems like those wires go direcctly thru a mess of conduit, then to pto side to run directly back , and a red and white wire jumps in that bundle which goes down chassis to rear.
If i take my ohm meter and check from the rear, it shows a reading on orange and brown...... But if i go to bars and check ohm on Orange and brown nothin with rear wires (brown orange) crossed..[took them out of their plug].
Does the orange in brown from bars go anywhere else in that mess of conduit ? Or is it a dirct run ?
All i did was pull motor for top end and mounts,, now suddenly no brake light....
Anyone know..?
I looked at all the wires w/ tank pulled back.. Voltage reg. wires all look fine....
Anyone know of anything ?
Jusr fired up sled, had orange and Brown plug detached from bars,, while running i am getting 12ish volts to those wires. So voltage is going to switch,, switch works... But no brake light.
Ran all new wire,, got brake lights now. Somewhere in the spagetti of harness there is a short.... left old wire in conduit,, but ran new to brake switch. DONE !
