fuel system
Boost it
Boost-it is the best thing you can do for your pl turbo. Get ready for a power increase too!
Boost-it kit. They flat work.. The only issue is getting one in the US. You might see if Alpine motorsports can get you one.
I believe that boost-it doesnt sell in US because of regulations. I could be 1005 wrong but i remember reading something about that on here awhile back.
neil stop dealing in the us for a bunch of reasons,but you could try alpine not sure if the could help yah.
What is the main advantage of going to boost-it over mcx system? Does anyone have any photos of the system installed they could post? Can fuel adjustments be made in the display while out riding?
The main advantage over MCX controller is all can to adjust in the field from the display. No laptop required. Switching over from an MCX system is pretty straight forward.
Here you got some pictures from when i installed Gen5 mcx fueling with Bluetooth on my MPI supercharged nytro.
Case for injectors welded in to plenum along with injectors and fuel rail:
This is how the readings look on your android mobile device:
This is how the recorded file looks when you open it on your computer.
Screenshot from TunerStudio MS where you adjust your "tune" when your are ready just send it to your mcx efi box using Bluetooth.
If you got any questions or need info i have tons of pictures of the install and will try the best i can to help.
//AG
And with MCX Gen5 with BT there's no need for an PC in the field, it's possible to change tune with a phone.
But WITH a PC you can autotune, just to get it "Spot on" easy as you want it.
After that, connect the phone, make some logging once in a while, analyze @ home or in cabin, just to compare to a baseline made earlier, to see if something is going on with the system (fuel, exhaust, vacuum, a.s.o.)
Skickat från min YP-G70 via Tapatalk 2
