did your fuel pump quit?
While the pump did work fine for the 5 days after adding the premix, I want to replace it anyways. I run a turbo on the sled and fuel delivery is not something that I want to leave to chance. The pump laboring couldn't have been good for it, who knows how long it will last, I don't wanna find out. Plus I'll just keep the old one for a spare. Spare parts are a good thing when you're running a turbo and you have to drive 1100 miles west to ride it.haha.
If you are having fuel issues with less than 1/4 tank, it's the smart valves not the pump. If the screen on the smart valve(the one on the high side of the tank) can't stay closed by holding fuel, it will suck air and stop the fuel flow to the pump. There have been issues with the valves. You can order the valves separate from the pump assembly from Polaris(2520873) or APE. You can also pull the pump assembly and inspect the smart valves for foreign debris.
Oil in the fuel is more than likely helping the screen problem.
The problem is more prevalent on Turbo sleds.
Go to www.apeusa.com and in the side bar open multi point pickups and read the info. It explains how the valves work.
You can get one for $120 from Auto Performance Engineering on the web.
Walbro F20000286 it is the same pump that is in your tank. You will need to take the old one out of the aluminum bracket.
