Fuel pump out
C
Clarke673
Somewhere between too dumb to quit and flat earth
Well after water skipping a few times this summer my pro has a bad fuel pump. :bounce:
Anyone have a cheaper replacement than the $400 polaris sells?
i pulled everything apart right away when it sunk but i forgot about the fuel pump haha. That kinda hurts though :brokenheart:
I can use a pump out of an CFI polaris sled right? i belive they are all the same.
You'll need to CAREFULLY remove the existing pump from the PFA (pump flange assembly) and be careful when you are installing the new one.
What is it off of? i just ordered one from napa for a 96 chevy truck. I think i can make it work. I will just have to put a fitting on where the sock filter would normally go to hook up to my fuel lines and sock filters that are in the tank.
Do we know what vehicle that came off of? My cost on the chevy pump is like $87
Not worth the hassle IMO, ... the above pump in plug and play... same as original.
I've tried the sock type pickup... sure you could get it to work... but how durable will it be?
This is the same pump above that is used in the sled..There is NO crossover for a car/truck.
I would have thought you would be jumping for joy when you found this piece!!
$30 diff for all the BS you are going to go through... HMMM????
YEA... BUT i want to ride yesterday. got the new pump in. Should work. All i have to do is a little rewiring. should only take me a few mins. We shall see if it runs. :bounce:
I'll post pics later, my droid droid died, and then my back up droid got murdered by a tailgate. Should work preeeettttttyyyyy smooth. If i had time to wait that would be a GREAT deal, thanks for the info MH, hopefully this helps someone else.
