Have my 144" skid out to replace cracked front torque arm and had Fox zero pros rebuilt/revalved for my weight (265) at the same time. Question for the suspension gurus out there.....I was thinking of installing the front track shock in the lower torque arm mounting hole with #225 spring upgrade from Carl's-limiters in the middle.....Anyone running with this set up/thoughts if my goal is to change track angle a bit for off trail and increase ski pressure on trail to get there? Don't want to crack another torque arm because of added pressure by changing shock position and not enough give with stiffer revalve/spring!
