front shock specs on Pro
Here Ya Go.
I assume you are talking about the two front ski shocks and not the front track shock.
If you are looking for used shocks that will "fit" ... Shocks that may fit your application will not be valved correctly for your sled... and will actually give inferior performance compared to the stock shocks. Even a "fancy" (eg X-EVOL, ELKA, EXIT, RAPTOR) shock will need to have the valving correct. On multi-adjustable shocks, even though the compression and rebound can be tweaked, the valve stack must still be designed for the sled you are riding and your weight/type of riding.
Have a look at this thread
http://www.snowestonline.com/forum/showthread.php?t=275565
2013/2014 600/800PRO RMK Shocks
Extended:16.63"
Collapsed:
10.86"
2011/2012 600/800 PRO RMK
PLUS 2011 - 2014 Standard RMK.
Extended: 17.50"
Collapsed: 11.50"
