Fox Shocks for 07-09 Phazers & Nytros
C
CarverPerformance
New member
Get your order in now to upgrade your Yamaha Phazer and Nytro shocks from the standard to rebuildable Fox Shocks. Better ride quality and more adjustability are now available to you.
2007-2009 Yamaha Phazer GT/RTX/FX
Ski: 850-12-200 Fox Float 2 $695.00
Front Track: 51-075 Fox Zero Pro $289.95
Rear Track: 52-075 Fox Zero Pro, 2" Body $289.95
2008-2009 Yamaha Nytro FX/RTX
Ski: 850-12-207 Fox Float 2 $695.00
Front Track: 51-074 Fox Zero Pro $299.95
Rear Track: 52-074 Fox Zero Pro, 2" Body $289.95
We will have the Fox Float 2s available for the MTX. Nothing for the skid frame.
There is a kit available to upgrade your original Fox Float to the Float 2.
Here are some of the advantages to upgrading your original Floats:
Increased negative spring rates. (This allows higher air pressures for better cornering.)
Higher internal air volume. (This gives the shock a more linear spring rate and allows them to stroke through better.)
Hi CD Flow Piston: Better bump response, especially over sharp bumps.
