Fox Rear Susp Settings (Evol & Zero pro)
M
maxitout77
Got this setup on the way for my Pro.
I'm 180lbs, 190 with gear. I do ride some bombed out trails and aggressive rider. What settings would you all recommend to start?
I'm about 5 lbs lighter but carry a lot of gear in my pack so we're pretty close.
135 psi main, 170 Evol, 7 clicks out rebound = Money. Set FTS to have 3/4" threads showing for Cascade Concrete or take all pressure off and just one turn preload if riding in lighter pow (Rockies). Add 15 psi to main and just one turn FTS preload if running serious steeps/chutes.
Note: Pressure needs to be done at riding temps, not in a heated garage. Tip sled on side at riding area and adjust air pressures if you need to.
Have FUN!
G MAN
thanks a bunch g !
i've been messing with mine all last year and i got all turned around
i think i was making too much change at once
any advise for a 205-215 lb rider 155 track
thanks again
thanks a bunch g !
thanks again
Go 5 psi higher for the main (10 if you're a real aggro rider), no change for the Evol, lower the FTS since you'll sag the rear more; a lot of bigger guys are just going with the minimum FTS which is one turn in of preload from where the adjuster just keeps the spring in place. Adjust in if steering feels too heavy.
Have FUN!
G MAN
