Fox Float2 PSI on Front?
M
maxitout77
About to bolt on a set of float2's on the front of my '11 Pro. Im 175 with some rough trail riding. What PSI would you reccomend starting at?
I usually start at 65 to 70#. Change it about 3 to 5 #s per adjustment. Once you are close, small adjustments make a big difference.
I weigh about 185 before gear and 210-215 fully geared up. I set the shocks at 68lbs and I removed the swaybar. I tried the sled with the swaybar in and less air pressure but I like it way better with it out at this setting. My main goal is to get to good powder but I have to ride 5-15 miles of trails just to get to it.
Yeah this is going to very on your preference. Depends if you like a soft front end or not. I have the the EVOL Rs and my main pressure is 50# and the EVOL chamber is 75. Not sure if that helps any but setting them at 70# seems a little stiff to me. Im 250# and no sway bar
