I keep fouling on the clutch side plug, recoil side runs nice and dry, brown, tan colour...clutch side is black soaked with oil. tried searching the site, but it says url not found on all pages i clicked on.
So do your best to diagnose and eliminate crank seals as the problem. Find someone with a leakdown test kit, or build your own from parts at the hardware store.
A crank seal will lose pressure and fail the test.
Monitoring oil consumption above, and below the center cavity hose outlet on the tank can be another good way to diagnose center crank seals too but is not as precise or indicative as a leakdown test.
Other things that could cause this are possible, here's a few that come to mind:
-oil injector failure (stuck open, oil fouling)
-sticking fuel injector (fuel fouling)
-weak spark on the fouling plug
