W
WHEREDAFUGAWEE
Hello fellow riders. I just purchased a new Fire N Ice intake assembly for my 2006 Polaris 700 (755) Rmk including the offset hoses that FNI sells to move the airbox away from the exhuast pipe. Problem: I went out for the first time this 2009/2010 season and the sled ran fine. About halfway through the day the sled started to bog down as i gave the machine throttle to the point of where it would almost flood out. I checked plugs and other possible areas of problems. I finally found out that the two FNI hoses had become disconnected from the CFI throttle body intakes. This allowed, i presume, warm air from the engine into the throttle bodies causing the motor to run rich. When i tried to reattach them and tighten down the clamps, the hoses would pop off again. I tried torqueing the clamps but they would just slip off the air intake assembly. Question is: Has anybody else had this problem and if so what did you do to keep the hoses attached to the throttle bodies?
