Float shock pressures?
Down
New member
Just installed a 2010 Pro Mountain Air suspension into my '09 MTX. What are you guys running for air pressures in the 2 rear suspension shocks? I weigh about 185. I'll be doing the zip tie trick, but I want to be somewhat close when I start out.
I'm running a Timbersled setup, but I run 90 lbs. in the front and 135 in the rear. I'm 200lbs with gear. I played around with it for a few rides, and you may have to do that as well. 5 psi increments seem to change so go little for adjustments.
