Flatbed Ramps
IFlyEm
Polaris Klim 509 BCA
I bought a 5500 with a 9’ 4” flatbed and now I’m trying to figure out the best way to use a ramp to load. I’ll be loading 2 sleds. Anyone have any good solutions??
Thanks!!
The best way is to have a secondary, thin, removable deck that sits on top that the ramp slides under and the superclamp anchors can bolt down through. We built this one out of a wrecked trailer. Four pins (1 on each corner) and it comes off and on with one person. We left it 12' long so plenty of landing area and could haul 3 sleds pretty easy.
However, based on your other thread you probably don't want to have something you have to take on and off to go between the camper and sled hauler mode. With the tapered rear end of the bed you kinda have to just set the ramp up in the middle with a strap to the receiver hitch, load one and slide it over with the rear end swung extra over, then load the second one. It's not bad and not a problem running them together if you use your head. When I was doing that the ramp would then go under the track of one of the sleds before strapping the rear of the sled down. I recommend making some 2x4 sides that drop into the stake pockets to keep the sleds from going off the side.
I did have a buddy build his side rails with an extension piece that went back to the outside corner of the bed. Then the ramp had something to sit on for being able to use the ramp normally on each side of the truck.
Yeah my biggest restriction is I need to be able to pull my gooseneck up to where were staying they put the sleds on the truck from there.
Caliber makes a couple different ramps that fold down. They are 90" long.
For loading two sleds onto your 9’ 4” flatbed, a flatbed towing service can be really helpful. They often have experience with various ramps and can recommend the best options for your setup. Also, consider using a wider ramp to ensure stability while loading. Good luck!
THIS SMELLS LIKE CHAT GPT BOT
Whoops, didn’t mean to sound too robotic! Just trying to help out based on my experience with flatbed towing. 😉 If anyone has better tips for loading sleds, I’m all ears!
Glad to see you are a HUMAN and not a ROBOT!!!!!
