black rivets, but you have 10 miles of alum tape under the hood! baaahahaha
Are you guys using your SLP rad block-off plate? or does the oem plastic close-off work better?
no, use the stock plastic close off plate for the 09-up...it has special contours in it to wrap around the lower 09 front bumper bracket...if you use the SLP one, you will have to cut a hole on the bottom of it for the bracket to fit..
