J
joshua335
Was the snow good yet in revy?
Yup, December conditions already. 3-4ft bottomless and more in some places... stuckfest for every sled. And still getting snow!
like others helped me with my sled a couple of weeks ago, Your TPS sensor probbably does not nead to be realigned, just pull the plug and dry it out.
They seem to come zip tied around the plug werid, it pulls the oring to the side, it gets mositure in it and your motor wont run right, i had many of the same problems as you, warning is it a PITA to get to, but get to it, cut that tie strap and pull the plug, there is a button on the back of the plug to release it, let it dry out good, plug it back in and see what happenes.
TPS needs re-aligned by dealer..........happened to my '11 at 35miles..
throttle position sensor/switch is my vote.
The 2012's have a boot on the TPS sensor connector..
How many flashes on the CEL?
Do what those above say... check the TPS connector.. and dielectric grease like Dave said.
Ethanol gas or regular?
Stock handlebars or aftermarket??
no beeper on a poo, and if its cold out they will idle faster...warm shop should idle 1700-1750..0 degree cold outside..around 2100 right after startup till warm, then idles down ...Well after a day drying in the garage it fires up and idles. Also goes into reverse again. I will re dielectric grease all connections tomorrow.
2 questions:
I can't recall if the sled is suppose to beep when in reverse? It is not doing it at this point.
What is idle suppose to be on a cold engine? Mike Taylor made mention to 1600, but it is idling 22-2500.
Thx
