Well we got 2 feet of snow last night so the first ride of the season on the new Pro Climb M800 was today October 9th.
Snow was not total powder but it was not late spring snow either, so kinda happy medium and lucky to ride this early. The meadows were totally hammered by my grand kids by end of the day.
I was really anxious to get the first ride on the new M800, I am coming off of a
09 M8 with all the updates. The 09 really is a fine sled and the pro climb will have to work hard to beat a well set up M8 2011/2009.
We rode in open meadows with some good rough ground with bumps if you wanted to hit that area. There was also some flat areas to ride in.
First thing I noticed was the clutching (6-9K) is smooth, pulls hard, and back shifts good. Even though the engagement is around 4K it is easy to turn the track without digging a hole. I cant wait to get it broke in and clutched a little better for peak RPM.
Now the ride, The new pro climb takes the bumps and rough ground so much better than the older M series sleds, I noticed it right off the bat.
But when you wanted to turn the sled at a slow speed or stopped in a tight area the front end would push. The older M series will turn in a lot smaller circle than the Pro Climb. In fact I had to use reverse to back up and turn again. I am not impressed with this issue. Either the skies suck, or some other problem is causing the push.
I was able to put 22 miles on the New Pro Climb today, it is by no means a
certified test of any kind. I am just telling you how my first ride in October was.
I did notice a vibration when you would let up on the gas and slow to almost a stop, I think it is a shied, or metal cover some where vibrating. I will explore what it may be.
Once I got home I proceded to check the plugs, be prepaired to dismantle to get the plugs out. I took the pipe off and looked at pistons. and plugs look good, so they must have the oil ratio set fairly close. plugs were not oil soaked, and had nice color.
One thing i noticed, I layed it over once on the clutch side in deep snow. The black fan on drive clutch rubbed on the side panel, so if you lay it over, shut it off or it will rub the plastic. So I am impressed, and look forward for the next chance to ride it. Hope this helps with needed info. With a little tweeking it will be a great sled. RickM
